Life expectancy of LS1?
Old Aug 14, 2009 | 03:59 PM
cjoelmitchell's Avatar
Default Life expectancy of LS1?
How many miles will the average LS1 last ?
I have 99 Z28 with 120,000. Car is in shop now getting most of the engine seals replaced, new water pump ,tune up and wondering how long I can expect the engine to make it before needing replaced
Thanks
Old Aug 14, 2009 | 04:11 PM
depends on how the car is treated. regular matinance like change the oil and dont abuse it and ull get 200k+ miles out of it.
Old Aug 14, 2009 | 09:39 PM
120,001 to 500,000 depending on how you treat it.
Old Aug 14, 2009 | 09:50 PM
robmnrd's Avatar
Yep, with proper maintenance, and if this tune up really does all that, it should keep running for many many many many more miles.
Old Aug 15, 2009 | 02:57 AM
Baldilocks01SS's Avatar
As with any machinery, an engine, if maintained correctly can run for as long as you can find replacement parts.
Old Aug 15, 2009 | 07:51 AM
While they have the engine pulled to replace the seals, is there anything else I should think about having done ?
Old Aug 15, 2009 | 08:00 AM
what seals are they replacing. front seals do not require the engine to come out. wow if the motors coming out i would pop the pan and replace the oil pump and check/change the bearings. but if a shop is doing it im sure they would charge big bucks. i would be tempted to throw a new motor in if i were u but then could not afford it right now and im sure u are probly in the same boat.
Old Aug 15, 2009 | 08:06 AM
They told me the rear main seal, and 2 other seals
Yeah I really cant afford to go with a new motor but this one still has plenty of power just had the small leaks
I can only spend around $3500 and they already quoted me $3100 so Im sure that will go up before its finished
Old Aug 15, 2009 | 07:11 PM
torque_is_good's Avatar
did you say $3100 ??????????
wow
Old Aug 15, 2009 | 09:50 PM
evilkal's Avatar
They ripped you off... Bad...
