Last decision.
#31
get a universal 2.5 inch x pipe from summit for 150 bucks, and pick up 2 magnaflow bullet mufflers for 60 a pop. then hook em up, pick up a stock cat from a junk yard (or if you have a bigger budget get 2 hi flow cats...) so you have one on each side, and then rig it all up... a half decent exhaust shop should be able to do the work for 100ish.
so, to sum it up... true dual Magnaflows. you would love yourself forever for doing that...
this is where I got the idea...
http://www.youtube.com/watch?v=k-083dKLrQs
**COMMON QUESTIONS**
- Yes, this will thrown CEL codes.
- Yes, this exhaust is illegal and will not pass emissions by any means.
- I did a lot of the welding myself, but I ended up taking it to a shop to have them go over it again with a MIG, get the exhaust hanger's put on right and put turn downs on. That cost about $100. I would not pay more than $150 to get this setup put on.
- I had to chop up the pacesetter y-pipe and use miscellaneous pipe adapters (can buy from any auto store) to make this work.
