Keyless Entry
Old Mar 23, 2013 | 04:53 PM
hunterview's Avatar
Default Keyless Entry
Hello all. I am having some trouble in my base model 1999 Camaro. My keyless entry has not been working for some time now. When I originally bought the car (last year) I was able to replace the remote and it worked for about a month. Then I replaced the battery, and then bought another remote, and I cannot get it to work. Is there a keyless entry module somewhere is the car I need to check? I am open to any thoughts or solutions. Thanks!
Old Mar 23, 2013 | 10:46 PM
hunterview's Avatar
Originally Posted by jkeaton
So you have two remotes and neither work? Or you had one that worked and quit working, so you bought another that worked for a month and then quit? You can try reprogramming them (it):
1. Turn the ignition switch to the OFF position.
2. Remove the RADIO fuse.
3. Cycle the ignition switch from the OFF position to the RUN position (as far as you can go without cranking the engine) 3 times within 5 second ending in the RUN position. The vehicle will verify entry into the programming mode by locking then unlocking the door locks.
4. Press and hold both the LOCK and UNLOCK buttons on the first transmitter for approximately 15 seconds. The vehicle will verify programming by locking then unlocking the door locks. Your new remote has been accepted and all existing remote codes have been erased.
5. Repeat the previous step for each additional transmitter (including any existing transmitters). You may program up to 4 transmitters. This must be done before the RADIO fuse is reinstalled.
6. Place the ignition switch in the OFF position. IMPORTANT: The remote keyless entry system will not be operational if the radio fuse is open.
7. Replace the RADIO fuse. If at any time it is necessary to restart the procedure, turn the ignition OFF and proceed again with step number 1.
I had one remote then it stopped working. I bought another remote and it would not work. The first one worked for about two weeks, then it stopped. It's almost like the signal got weak and died out. I programmed them both correctly, but the second one would not program at all after my first remote stopped working.
Old Apr 2, 2013 | 10:46 PM
MasonMPO's Avatar
Can you add OEM keyless entry to a 1995 camaro that it was not an option?
Old Nov 8, 2013 | 01:40 PM
autoexpert's Avatar
Default Best key FOB
This will help you..1999 Chevrolet Camaro Key Fob Programming Instructions:
1999 Chevrolet Camaro Keyless entry key programming instructions - ProgramKeyFob.com
Old Dec 31, 2013 | 02:42 PM
bluize3's Avatar
Works !! Thanks for sharing !
VanHalen
Jan 15, 2010 09:43 AM
fetuswrangler
Nov 12, 2008 10:24 PM
Hayden
Oct 24, 2008 02:31 AM
95TTop
Aug 14, 2008 09:38 PM
