Keyless entry
Old Dec 15, 2008 | 12:15 AM
nazariol's Avatar
Default Keyless entry
i just bought a new remote for the keyless entry for my 1999 camaro ss anyone knows how to program it?
thanks
Old Dec 15, 2008 | 08:01 AM
BLACKJACK's Avatar
Default RE: Keyless entry
didnt it come with instructions??? i want one but i cant afford it yet mabey in the spring ill have enough $$$$
Old Dec 16, 2008 | 09:01 PM
Jack2000LS1's Avatar
Something like turn power on and off three times fast and light will flash then press the unlock button on remote.
Old Dec 16, 2008 | 10:08 PM
kaoss_11's Avatar
you need a paper clip and need to jump the harness under the driver side dash
Old Dec 16, 2008 | 10:15 PM
nazariol's Avatar
what do u mean jumo the harness on the driver side dash? i heard there are some clear cut instructions anny one?
Old Dec 16, 2008 | 10:22 PM
95slvrZ28's Avatar
Have you checked the owners manual to your car yet? That would be the first place I would look. I've never had to do a remote reprogram on my car, but we did one on my Dad's 2000 Corvette and it was just a series of "do this" "press that" etc.
Old Dec 17, 2008 | 01:34 PM
wowcow's Avatar
here ya go... from the 99 Maro handbook, you can download below..
http://shbox.com/pdf/1999camaro.pdf
Section 2-8
Have each transmitter you intend to match ready for the
next steps. To match transmitters to your vehicle:
1. Turn the ignition key to RUN, then to OFF. This will
disarm the Content Theft-Deterrent/Alarm System
(if your vehicle has this option).
2. Remove the RADIO fuse. This fuse is located in the
main fuse block which is located on the left side of
your instrument panel. The radio fuse is located on
the lower right-hand corner of your instrument
panel. See “Fuses and Circuit Breakers” in the Index.
3. Turn the ignition key from OFF to RUN three times
quickly (within five seconds). The vehicle will respond
by locking the doors, unlocking the driver’s door and
releasing the hatch. Your transmitter is now ready to
match the vehicle. Leave the ignition in RUN.
4. Press and hold the LOCK and UNLOCK buttons on
the first transmitter for 15 seconds. The vehicle will
respond as in Step 3.
5. Repeat Step 4 for the remaining transmitters.
6. When you have finished matching all of your
transmitters, replace the RADIO fuse.
VanHalen
Jan 15, 2010 09:43 AM
fetuswrangler
Nov 12, 2008 10:24 PM
Hayden
Oct 24, 2008 02:31 AM
95TTop
Aug 14, 2008 09:38 PM
