Just to Verify, the Crank Position Sensor is under the Harmonic Balancer?
Old 06-06-2012 | 05:57 PM
DashingDaryl's Avatar
Default Just to Verify, the Crank Position Sensor is under the Harmonic Balancer?
My car will occasionally cut out for a split second when I'm driving, but resume 1/2 a second later without me doing anything.
At first I thought it was my fuel pump, but after replacing it, I still have the problem.
Yesterday it did it again and I got a CEL and a P0336 code (Crankshaft Position Sensor A Circuit Range/Performance)
Looking at this article I see it matches my symptoms pretty well.
On a 3.8 V6, is the sensor under the Harmonic Balancer?
Old 06-06-2012 | 06:15 PM
yep and you should take the pulley off.
tylerwerrin
04-09-2012 02:11 PM
t_jnorth
08-24-2007 10:56 PM
opus66
06-15-2007 12:55 PM
budzag@yahoo.com
11-26-2006 07:31 AM
skifast87
LS Series Tech
06-10-2006 05:13 PM
Quick Reply: Just to Verify, the Crank Position Sensor is under the Harmonic Balancer?
