Instrument Panel DEAD....
I've been researching the forum all morning and can't find anything yet so thought I'd go ahead and ask!
99 Camaro, 3.8l, convertible, approximately 86k miles. Belonged to my son's grandmother and she just gave it to him as a graduation gift. Here's the problem:
While driving it home, the entire instrument panel went dead: no odometer, gauges, speedo, nothing. Dash lights are fine, but not one single gauge works. Thought "no big deal" until i also saw the digital odometer was also gone. Any ideas?
Didn't get time yet to check electricals, but i did open up the radiator to a nasty surprise.....very thick, and i mean thick, mud in there. Smells like burnt transmission fluid. I'm going to assume the tranny oil cooler is cracked in there. Already ordered a new radiator. No water in the tranny as far as i can tell but i guess a fluid change and new filter are in order.
Dont jump to conclusions quite yet. The factory coolant is known to turn into mud if standard (green coolant) is added or just after being in the car too long. I would give the cooling system a good flush and clean it out first, then fill with only water and run around for a bit and see if there is oil in the coolant. If so then replace if not drain the water and replace with Prestone All Makes All models antifreeze, bleed properly and you should be good to go.
Massey
Massey
Well...
I have experienced that before with both my oldsmobiles. But, i checked all the fluids before we brought it back from NY and everything was fine. It hadn't been driven since last September. The radiator looked good too. But after driving it from Albany to here (maryland) the tranny was 1.5qrts low and the radiator was full of that nasty goop. So i figured what the hell...can't hurt to put a new one in i guess.
What other things would be a good idea to do since she only drove it from May-September every year? All new brake fluids, etc?
it prolly would not hurt to have the brake fluid changed out. I am going to have that done to my car later this month when I get my brakes done. I have no documents stating if the fluid has ever been flushed. My local shops are asking $50 for a brake system flush.
Massey
Massey
Crap
Well, I've checked everything i can check as far as wiring, fuses, etc. Found nothing. The dash is still dead... So, one of neighbors comes over and says "I think my sister had that same problem. She had to have some module removed, sent to GM along with a new one, and have the new one reprogrammed to match the old one (for the odometer) and then installed." Anyone know what the hell that might be? This is killing me. I can't get it on the road til i get this fixed and i sooooo don't want to have to take it to a slealership for ANYTHING......maybe i have no choice though?
