which injectors should i use
ive have a 58 mm bbk edelbrock throttle body with an edelbrock air gap intake for my 96 z28 but dont know which injectors i should use for maximum hp with no forced induction. i have herd accel injectors are nice but how many lbs should i go with?
RE: which injectors should i use
At a certian point bigger injectors are needed but not untill he does at least a cam and even then the stockers might work. Keep your stock ones for now, you are no where near maxing them out with your mods. Buying larger injectors now will only be a waist of money.
