Ignition Coil Missfire?
haha not the hood dono if u noticed but the wires go under the engine and there is a metal plate covering a good portion of the engine its hard to get to it i tried once and I barely got 2 wires out still wasn't able to change the plugs...beauty of the camaro i guess
The LS1 you can reach 7 of 8 plugs from the top and the only one you cant is the #8 plug which is on the right side rear of the engine. You have to go from underneath and that will take care of that.
On the 3.8L you have heat shields that make changing the plugs a little of a challenge. This can be a pain but trust me here when I say you need these shields and they are all in the way.
Massey
Massey
Massey
Massey
well for the center plug on both sides you need the shields off... You could bend them out of the way or cut them out. You should really think about keeping them in place, especally on the driver's side with the brake lines and steering gear parts right next to the exhaust.
Massey
Massey
Massey
Massey
Massey
Massey
Good to know...Like I said I hadn't tried just the rumor that I heard from a couple people.
#20
THe heat shields have nuts that hold them on to the studs in the manifolds. Mine came off really easy and none of the studs broke. Look on the exhaust manifolds you should see the nuts. If you have the 2000 or newer you will not have to worry about this since the redesign of the manifolds make spark plug access easy.
Massey
Massey
