i just got my first camaro!
the rims are stock but the tires are 18" .. not sure what the name of the tires are because im not picking up the car from pa until friday... also the exhaust is flowmaster--aftermarket (i dont know much about exhaust)..so to get 6le cme im assuming id have to change that obvs right? because i love that idea, along with the splitter.
the rims are 18"...and well if i dont have to change the company i wont, because i looked up the value of the exhaust and its worth 548$ ..and the cutting im assuming id have to have a place do? or can i try to do that?
The only thing that you "might" need to cut would be the pipes running off the muffler toward the rear of the car. Only reason that you "might" need to do that is for when installing the new CME tips they don't extend out too far, more of a personal preference type of thing. They also have valence kits for side mounts and new tips for those as well.
Flowmaster < stock exhaust < every crappy 4x4 truck with a flowmaster <<<< every other camaro exhaust
Value means nothing now. $550 is about standard for a catback, it isn't worth much once its been put under your car though. The 80 series Flowmaster has been shown to hold back power, just an fyi for you
okey thanks! also random question, what type of gasoline should i put in her? not what you think i should put in, but what is recommended in the drivers manual? keep in mind 1998 z28, not a v6 obvs.
