I have a question about key locks.
Old 09-17-2011 | 09:24 PM
94ChevyCamaroV6's Avatar
Default I have a question about key locks.
I have a 1994 Chevy Camaro V6 3.4L Car. Randomly one day I went to unlock or lock the car and the lock came out. I tried to put the lock back In but It Just doesnt seem to want to stay In there or want to stay In place. I saw that there was this rubber ring on the lock but that doesnt seem to work or help anything because no matter how long I have spent I cant get the lock to go back Into place then stay In place. I can get the lock to go back In and stay there but If I put my key In I have to hold the lock at the same time to not let It move and I am wondering how these go back In or If there Is a clip that Is supposed to be on the lock because all I see It a rubber ring thanks then.
Old 09-17-2011 | 09:32 PM
RFxCamaro's Avatar
Look under my history someone broke into my car and broke my lock and I put it back with quicksteel
Old 09-17-2011 | 09:41 PM
I dont want to know how to do It the wrong way I want to know how this Is done the correct way.
Old 09-18-2011 | 03:06 AM
yes there is a clip on the inside. gona have to take the cover off to get to it to fix and see if you can find the clip at the bottom of the door. be a good idea to get a new clip.
Old 09-18-2011 | 03:56 AM
RFxCamaro's Avatar
That is assuming that nothing was broken. Mine was broken and I wasn't about to replace my whole door because of it.
Old 09-18-2011 | 07:17 AM
Grandpaswagon's Avatar
As Craby said, there is a metal clip that holds the lock cylinders in from the back side. Sometimes they break and it sounds like your's may have.
You can sometimes find the clips at the auto parts store on the rack of miscellaneous parts (door handles, grommets, clips, etc) for about $2 for a bag of 3-4.
Old 09-18-2011 | 02:01 PM
Will the door have to be taken off to fix this or whats the way to assemble these then.
Old 09-18-2011 | 02:59 PM
gota take the inside cover off. i am again going to recomend you pick up a factory shop manual for your year.
Old 09-18-2011 | 03:21 PM
I will pick that manual up when I stop by the store to get spark plugs and a air filter I will get the basic one orielly has for like 25 bucks would you say those would be good or would a haynes one be better and I cant get one from ebay because I dont have a account then.
Old 09-18-2011 | 03:44 PM
i quit using the aftermarket manuals unless i cant find a factory book. they have so many years and models that the info is limited. have a look at them and see which look to be best for you. lol, i would at least look for the info i needed. shbox is good for some info. here is a link to how to change the window motor, about half way down it tells how to remove the door cover. Power Window Motor
