Humming sound in rear..
Hey guys im new here and have an 01 3.8L V6 model that makes a humming noise (sounds high pitched but not loud) in the rear when I run it for long 45 minutes or longer. The sound doesn't always come out it's only sometimes. Not too sure what it could be but I've been told it could be my fuel pump but I won't be able to replace till this weekend. Any help or advice on what is causing this sound is appreciated.
Does it do it with the car moving or does it go away with the car stopped?
If you shut the car off then just turn the key back on (without starting it) the pump should run for seveal seconds. It would be the ONLY thing in the back of the car doing anything.
If its your pump do not expect it to last very long. Most of the time once they start making noise you are hours away from a break down.
I have a similar problem as well. Except I think mine is coming from the exhaust area.
Does it sound like a high pitch hissing? Mine has been doing it since last year. If it was the pump, I'm sure it would have died by now.
I mean y after 45 minuets of driving?
temperature?
