how tight for sway bar links?
http://i1053.photobucket.com/albums/...ps69d2eb50.jpg
old and new the other day I noticed that the link on the passenger side was completely missing, so I replaced both up front. How tight is it supposed to be? I tightened it until about 1 inch of treads was pulled through the nut, is that enough? |
Book says 17 ft-lbs (204 in-lbs). Some Loctite never hurt either.
If using poly replacements, do not smash the poly, only tighten enough so there is no play in the link, else the poly will deform.
LS1TECH - View Single Post - Rear sway bar problem.... (with pictures) |
Originally Posted by libertyforall1776
(Post 679537)
LS1TECH - View Single Post - Rear sway bar problem.... (with pictures) thanks for the info, I didn't tighten them as much as the one in the picture. and I just went with standard rubber |
| All times are GMT -5. The time now is 06:52 AM. |
