How to tell "True SS"?
Its a z28 with all the SS accessories on it (hood, spoiler, badges, grille). I just carfaxed the vin: 2G1FP22G122139916
I would only buy that if it had an M6 instead of the A4.
The car is NOT, let me repeat that NOT an SS Here is a break down of the car's RPO codes
UA6 THEFT DETERRENT SYSTEM ANTI-THEFT(UA6)
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
UK3 ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
UN0 RADIO,AM/FM,STEREO,SEEK/SCAN,COMPACT DISC,AUTO TONE,CLOCK,ETR STEREO W/CD PLAYER(UN0)
UZ7 SPEAKER SYSTEM 8, QUAD FRT DR MTD, DUAL SAIL PNL, DUAL RR HATCH, AMPLIFIER 8 SPKR SYS(UZ7)
U73 ANTENNA,FIXED FIXED ANT(U73)
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
V12 COOLING SYSTEM,POWER STEERING FLUID P/S CLG SYS(V12)
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
Z28 PERFORMANCE PACKAGE,SPECIAL PERF PKG(Z28)
SPECIAL PERFORMANCE PACKAGE,(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(Z28)
1SD PACKAGE-OPTION 04 (1SD)
1SZ PACKAGE OPTION- (1SZ)
19I INTERIOR TRIM COLOR (19I)
INTERIOR TRIM,BLACK (19I)
INTERIOR TRIM,EBONY (19I)
192 TRIM COMBINATION,BLACK LEATHER (192)
6BS SPRING COMPTR SELECT FRT LH SUSP(6BS)
7BS SPRING COMPTR SELECT FRT RH SUSP(7BS)
8TJ COMPONENT RR LH COMPUTER SEL SUSP (8TJ) SUSP(8TJ)
81Q MOLDING COLOR - BRIGHT RED (81Q)
81U EXTERIOR COLOR,PRIMARY (81U)
EXTERIOR COLOR,PRIMARY,BRIGHT RED (81U)
9TJ COMPONENT RR RH COMPUTER SEL SUSP (9TJ) SUSP(9TJ)
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1)
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31)
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90)
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
CC1 ROOF,HATCH,REMOVABLE PANELS,GLASS HATCH RF(CC1)
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
DE4 SUNSHADE,REMOVABLE HATCH ROOF HATCH RF S/S(DE4)
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING RIDE & HANDLING SUSP(FE2)
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5)
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
IP2 TRIM,INTERIOR DESIGN (IP2)
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
K43 GENERATOR 102 AMP 102 AMP(K43)
LS1 ENGINE GAS, 8 CYL, 5.7L, SFI, ALUMINUM ENGINE 5.7G(LS1)
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
NF7 EMISSION SYSTEM FEDERAL, NLEV FEDERAL EMIS NLEV(NF7)
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
NW9 TRACTION CONTROL ELECTRONIC ELEC TRACTION CONT(NW9)
PW7 WHEEL,16X8,STYLED(ALUMINUM)(SUPERLIGHT) STYLED AL WHL(PW7)
QFZ TIRE ALL P245/50ZR16 BW R/PE ST TL AL3 TIRE(QFZ)
SLM SALES PROCESSING - STOCK ORDERS
STE PLANT CODE- ST THERESE, PQ, GM OF CANADA ST THERESE,GM OF CANADA PLANT CODE(STE)
T82 HEADLAMPS,AUTOMATIC ON/OFF CONTROL AUTO HDLP CONT(T82)
T96 LAMP,FRONT FOG FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH TOURING YP6) FRT FOG LP(T96)
There is no WU8 so not a true SS
Massey
Massey
I decoded that from http://www.compnine.com/vid.php
In any SS car look for the WU8 on the door or if it is missing on the door then look here.
Oh and 97 was the first year for the SS.
Massey
Massey
Not more than 10K. The additions like the brakes do add value but not for 20+K, it is nice and clean but it is NOT an SS it is simply a Z28 and a very well built one at that. Also dont let them tell you it is an annaversary model... That plaque on the dash is on ALL 2002 Camaros.
Massey
Massey
