How much do you spend on gas per month?
Between both my vehicles probably $250 on the high side. But there have been times where I put one tank of gas in a vehicle in a month. Actually just came back from filling up the camaro. 14.3 gallons of 91 ran me $51.
Deciding factor in what? Keep in mind what others spend could be so far off of what you may spend. For instance, my dd is a truck that I am constantly running back and forth between my office and the NAVY base here during my normal working hours. So large fuel tank plus 14mpg = I spend a lot on gas. You might only use your vehicle to go back and fourth to work and maybe out on the weekends so you could easily be under a $100 a month. It all depends on how and how much you drive your car. I saw your post in the lounge section and commented on that too. I assume you are new to driving and car ownership. Keep in mind you will also need insurance and money for maintenance. If you end up getting a loan for your car you will need full coverage insurance and full coverage insurance for a 17yo in a Camaro is really expensive, unless you go on your parents.
I usually put $20 bucks in my car every week and a half, so call it $80 a month and I do a decent amount of driving and use 93 oct. only. The fuel mileage isn't as horrible as people make it out to be, nor is the insurance. For instance, my insurance only went up $30 when I switched to the Camaro and that was going from a Buick Century. Though, from personal experience, the Z28's aren't exactly the best car for a new driver. Can (and will) get you in trouble and winter can be a PIA without winter tires.
With my 3800/5 Speed I drive 31.5 miles each way to work. (5 day work week) In the summer I normally put in 10.5-11.0 gallons a week. In the coldest part of the winter that will go up to 11.5 to 12.5. I am not sure how much of that increase is cause by colder denser air or allowing the car to warm up twice a day. When I built my 3800/5 speed I was doing 55 miles each way.
Of course this excluded traffic jam and delays.
I track the fuel usage every week as it is a great indicator if a sensor is going bad. It will show up in MPG long before it sets a check engine light. I get gas at the same pump and stop at the first click every time. It is not supper accurate but over time it will average out.
If it’s a good job you should look at the commute and make sure you have the right car for it. I have been commuting for a long time now. The Camaro is a heavy car but she cuts through the air better than most. That allows for great highway mileage with the right setup. This heavy car would not be great if I had dozens of stop starts. If I have an in town commute I would look at a 5 speed cobalt type car.
As for fuel, i probably spend upwards of $200 a month in fuel in the camaro alone. I wont be driving it much this summer.
