How do you take Governor Off I Need Help
I Need to know how to take My governor off i have a 1998 Camaro 3800 Series V6 with single piece driveshaft from Driveshaftshop.com and couple more mods and i know my car will go faster than 120 but it just stays there and i am only at 4k to 4500 Rpm I got a Manual and if anyone knows how to take it off please let me know cuz progammers are like 360 dollars Need Cheap Mods to Please feel me In CAMAROS RULEEEEEEEE
RE: How do you take Governor Off I Need Help
Why do you need to go faster? Find a Camaro owner near you who has HPTuners, and have them fix it. Or maybe a dyno shop can tune it out for you. If you can't afford a tuner, then you probably can't afford a wreck from 120+, so be careful.
If you don't have "Z" rated tires the speed limiters is on the ECM for that reason. The stock "H" rated tires are only good for speeds up to 115MPH. So leave it alone.
Is it easy to tell the rating of your tires? Is it listed somewhere? And if you get new ones on, how is the computer changed? I am guessing it has to be done at the Chevy dealer right?
As far as I know, there's only 1 way to do this. The governer is in the computer so you can either take it to a dyno shop, like it did, and he'll tune it out, or you buy a self programmer and do it yourself. Really your only options if you want your car to go faster. Upgrade your tires if you do this too to be safe.
Jigen: The speed rating is the letter in your tire's size, for instance my tires are a 275/40/ZR17, 275 cm wide, 40% of 275 cm tall, speed rating Z, R-radial, 17" rim.
armynatguard18: It's possible to go faster, but that probably means your car isn't governed from the factory, wich means it came with Z rated tires. They were an option that you could order when you got the car. So, 1993-1997 came with S rated tires and were governed at 108 mph, 98+ came with T rated and were governed at 115 or you could pay more and get Z rated tires from the factory in which case your speed rating is 149 mph+ so the cars are not governed at all.
