how can i
Old Apr 23, 2008 | 02:44 PM
meteoralp45's Avatar
Default how can i
clean up my engine bay??
Old Apr 23, 2008 | 03:44 PM
95slvrZ28's Avatar
Default RE: how can i
DO NOT PRESSURE WASH IT!! It's the fastest way to the death of an opti. If you want to clean it up a bit you're best bet is probably going to be some 409 and some time with a sponge. I'm probably going to do the same thing to mine when I have it appart doing top-end work. You can also use dish-washing soap thinned with water because it's made to cut grease as well. Just be careful not to get anything dripping down the front of the motor and you should be good.
Old Apr 23, 2008 | 04:01 PM
werd
i just wanted to have her lookin good till i rebuild her and then ill be able to get her clean and keep her clean.
would it be safe to use alluminum polish on the intake manifold?
Old Apr 23, 2008 | 04:28 PM
qmracer's Avatar
Get some foaming engine degreaser and just cover any open electronics and your air filter with bags. Stuff works great but after that 409 and a sponge like was stated. An old STIFF toothbrush is nice to have as well.
Old Apr 23, 2008 | 05:00 PM
SpecterGT260's Avatar
Ninja Administrator
when i was finishing up my cam job a buddy had a bottle of quick detailer with him. its a continuous spray aerosol. doesnt foam.... kinda like pledge for ur car. it worked WONDERS. took all the grease and gunk out. which im sure will make u guys happy if i post new pics since u all yelled at me to clean the bay last time
Old Apr 23, 2008 | 07:03 PM
lol i would like to see some
Old Apr 24, 2008 | 12:50 PM
LT1RUNNER's Avatar
I've washed my engine plenty of times with no problem (knock on wood) however I did have an issue once and it ended up being the rubber washer that protects the connections in the opti from corrosion was worn out. Replaced and no rpoblems since. I do stay away from the opti when cleaning the engine bay but if water goes there then so far I haven't had any issues other that the one time. I usually shove a towel down there so soak up any water that gets in that area. Never can be too sure.
