how to bypass express down module?
Does anyone know how to bypass the express down module if it is possible?
I cannot find a module anywhere locally as far as junk yards go. I heard that you can bypass this module by splicing some wires? ANY help would be excellent. Thanks |
I am looking to work on the driver side.
1. Unplug and remove the Express Down module, mounted to center of the dash mat above the floor tunnel. Place a tag/label on the connector for the express down module: "Do not install unless jumper inside driver-side door is removed."
2. Inside the door, jumper the gray wire at the window switch to the brown wire at the window motor. Put a tag on the jumper stating it's purpose. |
nice, thanks
Other modules, if installed, are in the general same area. Just to make sure you have unplugged the correct module, check to see that the window no longer works. If it does not work, proceed to step 2.
Window Madness
Made the jump, window is up but will not go down, nor will the passenger window. I assume because of the EDM module being removed..?
