homemade lowering job
hey i know there have been posts about this i just couldnt find them nor do i think they had what i was looking for, either way
I'm trying to buy into the replace the rear insulators with a heater hose (i boguht a 5/8" one) and was wonderign for the back all i do is remove the wheels and pull the spring or do i have to unbolt anything else? and does the hose have to go asround the entire spring or jsut the top end?
thanks guys =]
thanks guys =]
How would lowering the carmake it failinspection? Here is a walkthrough baseballer91...
http://forum.camarov6.com/showthread.php?t=82033
After reviewing that mod post, i stand corrected. That would not be noticeable to an inspection mechanic. Looks like it knocks off about an inch. I thought you might be referring to heating the coils or some other such back yard mod.
ORIGINAL: SpecterGT260
its more common and probably safer to cut a coil off of the spring.
![Big Grin](https://camaroforums.com/forum/images/smilies/biggrin.gif)
nah id rather have it so if worse comes to worse i coudl take the hose off and put the insulator back in
and thank you 02stangt, i could not find that ANYWHERE. =]
To answer your other question, you don't want to take your wheels off. You need to unbolt only one end of both shocks, and your panhard/sway bars. Jack the car up by the frame, and the rear tires will stay on the ground. Jack it up enough to clear the springs and pull them right out.
ORIGINAL: Camaro 69
damn im dumb. proly saved me a good 5 - 10 mins total
The mod looks easy enough, but how does it effect the ride? I've been looking at the Summit springs in thier catolog. They cost $160 for about a 1.5inch drop. Has anybody used these? Are they worth the money compared to the mod?
