HELP with Window Motor
My local technician said that it will cost around 200 bucks to fix the motor of my 1996 camaro convertible rs v6 3.8l. i was wondering if it is possible for me to buy the motor myself and install it would be cheaper but i don't know what type of motor i checked on ebay theres two motors one that is $60 and one that is $90 the 60 dollar one is a NEW Driver or Passenger Side Window Motor GMC Safari. The 90 dollar one is Window Regulator NEW WITH MOTOR POWER Driver Side PART. plz help
Check out this link.
AutoTrix :: Window Fix Kit with Motors Bundle
You get two motors (one for each window), and the complete wiring kit necessary to correct a substandard factory design. Install this kit and you will never have another problem with your window motors.
You only need basic hand tools and general knowledge of car electrics. They also have a very detailed installation sheet that steps you through the whole project.
I used the kit, and didn't actually replace the motors in my doors. My passenger window was very slow going up. After fixing the wiring, it actually goes up faster than the driver's window. Once I did the wiring kit on the driver's door, now they both go up and down in just a couple of seconds.
So, you can use the original motors, as long as they still work. But if your window won't go all of the way up or down, you may have another problem that you need to address in addition to the wiring.
cornmuffin
07-24-2014 10:22 AM
