Help maintaining my camaro
RE: Help maintaining my camaro
Unless the prior own tells you the car is fully serviced, I would generally replace all the fluids if your going to drive the car a while before you rebuild the engine. Brake fluid, power steering fluid, rear differential, trans fluid/oil, engine oil, coolant. Load test the battery while your at it.
