Help! Coolant leak!
Old Sep 17, 2012 | 07:12 PM
djsquare1's Avatar
Default Help! Coolant leak!
I just got home from work and noticed a pool of coolant dripping down from the engine. I jacked the car up and tried to pin point the leak.
It looks like it's coming up from around the crank pulley, so I am guessing it could be coming from the water pump?
It's the "wettest" under the front axle but I think it's just trickling down the engine making it seem like it's coming from right under the block.
FYI I flushed my coolant a week ago and didn't bleed the air out of the system. Maybe this was my bad?
Heres a picture of what I could see:
https://picasaweb.google.com/lh/phot...eat=directlink
Old Sep 17, 2012 | 07:17 PM
2Z's's Avatar
Link isnt showing up
Old Sep 17, 2012 | 07:24 PM
nashcar's Avatar
Probably water pump gaskets, one problem with the aluminum engine.
Old Sep 17, 2012 | 08:36 PM
djsquare1's Avatar
Fixed, thanks.
Good call. I can't see where the leak source is, but I wouldn't doubt that you are right about the gaskets.
Since I need to remove the pump to get at the gaskets, I might as well buy a new pump so I know I won't have to deal with it again, right?
Old Sep 18, 2012 | 06:37 AM
nashcar's Avatar
That's what I did.
Old Sep 18, 2012 | 06:52 AM
Edwardgp's Avatar
Water pump gasket.
Old Sep 18, 2012 | 10:30 AM
djsquare1's Avatar
Can I use gasket maker temporarily or do I need the alum. gaskets?
Old Sep 18, 2012 | 04:57 PM
greenarrow's Avatar
September 2009 ROTM
Do you really want to do it again?
Old Sep 18, 2012 | 05:28 PM
REN's Avatar
REN
You should also replace the water pump bypass hose too, my leak was coming from that.
3.8L-V6 Camaro Firebird Pump Elbow Heater Hose Lower
Old Sep 18, 2012 | 09:28 PM
djsquare1's Avatar
Today I took the pump off and started scraping the gaskets off. It had either a paper gasket or was the liquid gasket, either way it's tough to get off. I bought some water pump liquid gasket, but I will be returning it tomorrow and ordering the 2 new gaskets off ebay since none of the parts stores have them here.
There are the paper gaskets on ebay for $2.50 + $18 shipping and the alum ones are $10 + $32 shipping to Canada. -OUCH!!
Can I get away with using the paper ones?
Will I need to use anything with the gaskets or just throw them back on after I clean it?
