Help
Okay so noticed something a bit funny on the backside of the MAP sensor of the wifes 99 v6 camaro. Noticed the nipple had broke that had a small vaccume hose on it. What part do i need to get to fix it. The hose went from the map to the feul regulator i think. Please help because nobody seems to be able to help me at all.
1 Attachment(s)
Check the illustration in the attached file. If this is what you're referring to, the parts book calls it a vacuum manifold #24503419. According to GM Parts Direct, this part number is not available.
Originally Posted by peterpar
(Post 725516)
