HELP!!!
RE: HELP!!!
A random misfire can be any great number of things. I suspect it's electrical. A plug and wire job certainly won't hurt. If it persists, trying looking at the coil packs and ignition module. I'd actually spend 30 minutes and inspect every plug wire, looking for burn spots and areas that could allow a spark to arc to a hot manifold or block.
RE: HELP!!!
That's the oil pressure sending unit. The diaphram must be broken. Simple to change out and easy enough to get your hands on. It's a standard part. Any good parts store should have it for under $25.00.
RE: HELP!!!
ORIGINAL: stuyacht
what could cause that to break? it just kinda happened...
