hello 98 camaro 3.8
i just got my tax money finally heres what I can spend 500 bucks or so I want to start with
spark plugs
wires
coil packs
crank shaft sensor
shocks and struts ? think I can stay under 500 bucks
is there any sites where I can get parts cheaper than autozone or advance
spark plugs
wires
coil packs
crank shaft sensor
best deal on bilsteins 93-02 Bilstein HD Shock Package (Set of 4 | Shocks/Struts | WS6store.com
bilsteins or the kyb AGX adjustable are the cheapest shocks you will want to go with.
Acdelco coils never going to beat this price New ACDelco Ignition Coil Set 3 D555 C1235 DR39 | eBay got mine form them also
rockauto is going to be the best for acdelco wires and plugs
the most common plug for a NA 3800 are the NGK TR55 around $2 at rockauto
FYI the 3800 runs best with stock ACdelco ignition components
I was bout to order my parts from rockauto but I want to make sure im buying the rite parts can someone look and see if they will work on my car 98 Camaro 3.8 automatic
plugs nkg 2.49 part #3404
wires ? need help give me suggestion
crank sensor 18.76 part # pc30t
fuel filter 2.47 part fg1106
getting my coil packs and control module off ebay
oil pressure switch 17.25 ps277t
so am I getting the rite parts since the mechanic will be able to work on my car for one weekend comin up or ill have to wait till june which I don't want too can someone help me out
get ACDELCO wires Part # 706X
everything else looks fine, but if it was me I would stick with acdeclo parts, 3800 doesn't play well with other brands.
why are you replacing the crank senor? you know the crank bolt is tty one time use, you'll need a new one, INTENSE Racing: Crank Bolt yes it fits the fbody, I order mine form them.
Says who? I run MSD wires & Denso Iridium plugs (stock heat range) in my 3800, runs great, as suggested here:
- Camaro RS V6 Project Car
Koni Str.t or Bilsteins on all fours. Stick with Moog bushings IMHO, except for shock mounts- OEM one is beefier.
*- Camaro RS V6 Project Car
Pretty much every v6 forum and big v6 builds, even most the guys on ls1tech agree that msd parts are junk. I even had msd before, and my car always ran like crap. Went back to acdelco wires, haven't had a problem yet.
Op get what every you want and learn the hard way.
