heater problems in 93z
Old Nov 17, 2008 | 04:39 AM
93maroonz's Avatar
Default heater problems in 93z
I just bought a 93 z-28. I drove it 100miles to get it home and it ran fine. The temp was ok but no heat. I found a lot of things wrong after getting it home. I washed it and it would not start. I burned up the starter so got a new one. I was then told to dry out the disty and thats where it got pricey. I broke it getting it off. So it now has a new disty, cap, plugs, and wires. I also noticed the water pump was bad when I had it off. So that got replaced with a new one as well as the thermostat. After all that I still have no heat. I flushed the system out and that did nothing. I felt the heater core hoses prior to the flush and they were both about the same temp but it was not hot. Oh after I got all the parts on and got it running again the temp guage will not go over 120. Not at idle or in town or on the high way. I have put close to $1000 in parts into it all in the same week I bought it. So I am now broke and cold. If anyone has any ideas please help.
Old Nov 17, 2008 | 11:17 AM
02StanGT's Avatar
Default RE: heater problems in 93z
It is possible that the heater core is plugged completely.
Old Nov 17, 2008 | 12:18 PM
93maroonz's Avatar
i am not sure. I guess it could be. I read through the fourms and someone said something about blowing air in it. other that it looks a bit hard to get to any ideas on if i can do this at home or is there some tool i would need?
Old Nov 17, 2008 | 10:08 PM
If the temp really stays below 120, it is a good sign that the t'stat is stuck open. Verify the temp gage is accurate.
Are the fans on at such a low temp?
If the heater core is clear, both hoses should be at the same temperature, and be as hot as the radiator hoses. If not, try disconnecting both heater hoses at the front of the engine, stick a garden hose with a nozzle into one of the hoses and turn the water on. The water pressure may be enough to blow all the gunk in the heater core out the other hose. Also one of the hoses may have a restrictorstuck in it near the front end of the hose. Pull the restrictor out and make sure it is not clogged.
Old Nov 18, 2008 | 02:58 AM
93maroonz's Avatar
thanks for the help guys. I decided to not belive the guage today as i ran out of gas and it said i had 1\4 tank. End result the plug in the cluster was loose so the temp might have been wrong as well. As far as the heater I read apost saying something about blowing air in the heater core so i pulled one of the heater core hoses and blew air into the system and it took alot of pressure then out of nowhere a pop and a rush of water and antifreeze came out of the heater core. I put it all back togeather and filled the radiator but it is to late to start my car as its 2am so i will start it in the morning and see what happens.
Old Nov 18, 2008 | 11:53 AM
02StanGT's Avatar
Hopefully it worked. It's never too late to start a car, by the way.
Old Nov 19, 2008 | 07:42 PM
93maroonz's Avatar
well it did not work. so i guess i will go buy a new heater core. but the odd thing is the car still is not going above 120 degrees ans water came through the core so i am stumped.
Old Nov 20, 2008 | 03:11 PM
93maroonz's Avatar
ok well I gave it one more shot. I have read post after post saying check the heater core and so I went ahead and pulled it out and hooked the hose to it directly any sure enough crap came out and now I got heat. thanks for your help guys.
budm
Nov 26, 2012 05:10 PM
SimplexDesign
Jan 5, 2009 12:24 AM
sl1foru
Oct 23, 2008 06:19 PM
sl1foru
Jan 31, 2008 06:23 AM
dhighway
Jan 12, 2008 07:28 PM
