-   93-02 General (https://camaroforums.com/forum/93-02-general-41/)
-   -   head light problems (https://camaroforums.com/forum/93-02-general-41/head-light-problems-25504/)
95 z28 camaro Mar 9, 2008 08:42 AM
head light problems
hey guys, i have a 1995 z28 camaro, and my head lights keep blowing out with in a time period of 2 months. i talked 2 one of my buddies and he thinks its something in the harness. what do u guys think?
z28pete Mar 9, 2008 11:15 AM
RE: head light problems
The harness can't increase voltage to make the lights burn out. The only bad thing the harness can do, is toprevent the lights from going on doe to damaged wiring or shorts.
Camaro 69 Mar 9, 2008 12:10 PM
Are you replacing the whole headlight, or just the bulb portion? (and yes, you can replace just the bulb)
If you are handling the bulb, don't touch the glass with your bare hands. Oils from the skin will cause a halogen bulb to blow prematurely.
kaoss_11 Mar 10, 2008 03:01 PM
since you have a 95 I will assume you are using the sealed beam headlights. opnly thing I can think of is there may be a short some where or to big a fuse maybe.
95 z28 camaro Mar 11, 2008 11:44 AM
ive been just replaceing the whole headlight, than put the blown out one in the box and return it, so im not waisting 25 bucks every 2 months. could be a fuse (i hope its that and not a short) ill take a look
