head gasket thickness
Which engine? If an LT1, the stock compressed thickness is .050. GM part # 10168457.
You can also get part # 12553160 which is around .028 made for the Impala iron head LT1. That will bump your compression and h.p. slightly. But you might have to run primo gas after that.
