having an high idling issue
hey i have a 1993 3.4 and when i start it up it revs to 1500 rpm and i just wanted to know what are the common vacum leaks occur in these cars
any help would be much appreciated
granted i have a z28 5.7, from a cold start idles at around 1000rpm till it heats up then drops down to around 600rpm.
1500 seems kind of high to me. check your IAC valve & motor, there's been a lot of this going around lately seems like. if its all carboned up simply clean it off and you should be idling normally. if not, then im not sure.
