ground locations
I think so the cross over pipe should be the pipe that runs under the oil pan. It "crosses" from one side of the engine to the other.
I am not a 3.4 expert but those pipes do not nomrally have gaskets. In many cases that are just ball joints that can not be replaced or the are a sleave like seal that would only "needs" replaced if it fell apart when you removed the pipe. If you look it up in the manual it should say must be replaced if it needs to be replaced everytime.
