-   93-02 General (https://camaroforums.com/forum/93-02-general-41/)
-   -   Ground Locations (https://camaroforums.com/forum/93-02-general-41/ground-locations-68714/)
Chris Wood Mar 18, 2012 12:21 AM
Ground Locations
Does anyone know were most of the stock ground wire locations are on a 2001 ss? i keep getting a short somewere and its blowing the tail light fuse. normally a 20 amp. it works for a few hours and then it blows agian. anyone ever had this issue? and if not any ideas on were i should start looking before i rip the interior out to check every wire inch by inch?
craby Mar 18, 2012 09:18 AM
pick up a repair manual for your year and model. i doubt its a ground wire issue, most likely a hot wire being grounded. do you have a aftermarket amp mounted in the hatch area. the harness in the hatch area has been an spot for issues. i would think the coluum is another spot that you would want to look.
Chris Wood Mar 18, 2012 10:16 PM
Thanks for the advice crabby, i checked both today and found nothing wrong. its wierd. sometimes it works then others it blows the fuse instantly. well im cold as hell out of beer and im missing part of my skin on those sharp plastic edges. time to call it a day. try again next week when i get time off... and no amp. its not stock stereo or speakers either.. i may try rewiring it later. whoever had this car before me didnt know wiring at all.
craby Mar 18, 2012 10:32 PM
oh boy,,, look for any work done and redo is a good plan. may have wired something into that circuit, anything else not working?
Chris Wood Mar 18, 2012 10:41 PM
nope its just the tail lamp fuse, which kills the dash lights too. i just tested it with a 50 for giggles and it blew it too. im getting frstrated. i work 86 hour weeks and that doesnt leave much time to do anything
craby Mar 18, 2012 10:47 PM
that should have heated the wires up and where the short is. careful you dont get things to hot, dont need no fire.
Chris Wood Mar 18, 2012 10:49 PM
i had the fire thought go through my head right after it popped lol
fire would show me exactly were it is though
craby Mar 18, 2012 10:52 PM
lmao,,, now that there made me laugh.
Chris Wood Mar 18, 2012 11:39 PM
hmm the brake lights still work and all the lights light up when i hit the lock buutton on the remote..... im so confused >.>
