gauge fuse keeps blowing
Old Dec 1, 2014 | 01:30 PM
mikilla's Avatar
Default gauge fuse keeps blowing
I have a 93 v6 automatic the gauge cluster fuse keeps blowing and I found 2 wires melted together that go to my brake pedal switch what do these wires go to? My brake lights work fine, I just put in a new transmission I was wondering g if maybe the plugs on the trans would make those wires melt?
Old Dec 1, 2014 | 01:58 PM
mikilla's Avatar
This is a pic of the wires, the brake pedal switch has 2 plugs one with 2 wires and one with 3, and they are covered by the blue cap thing you see in the pic, what do these wires go to?
Old Dec 1, 2014 | 05:55 PM
Stepping on the brake pedal defeats the torque converter lockup and cruise control. I'd have to see a schematic to see what's what. Were you having this fuse problem with the old transmission?
Old Dec 1, 2014 | 07:09 PM
mikilla's Avatar
Never had this problem before, now my car won't charge alternator is brand new
Old Dec 1, 2014 | 08:59 PM
GaryDoug's Avatar
The instrument cluster needs power to enable the alternator.
Blown Gages fuse=no alternator output.
The Gages fuse also provides power to one section of the brake switch which is connected to the transmission TCC solenoid (light-blue/black wire at pin A of the transmission connector)
Old Dec 8, 2014 | 11:07 PM
J-Factor's Avatar
Melted wires are never good. Fix those first and test for shorts. Wiring diagram would cut down the time significantly.
Phirewire
Dec 6, 2013 11:59 AM
vnctvega
Oct 18, 2012 11:31 AM
izayuhgawd
Nov 21, 2011 09:24 PM
JL15689
Oct 15, 2009 10:37 PM
Tealcam
Sep 1, 2008 10:42 AM
