Fuel Line Removal
hey, so i got a step by step instruction for dropping the engine. been working on disconnecting things. the fuel lines are not moving. according to the instruction i have been using, i am supposed to get a 3/8"s fuel line disconnector. what is this and is there a way to use something else?
I have had no luck getting the fuel lines off without the tool. You can buy them at any auto parts store for about $10. Get the metal ones and don't waste your money on the plastic ones. Also, make sure to bleed off any pressure before you disconnect and don't let anyone sit in the drivers seat and think they are going to listen to the radio and shoot fuel across the garage when they turn the key on!
Link to pic
http://shop.advanceautoparts.com/web..._T|GRP2083____
This tool spreads apart and goes around the fuel line. The tapered end will slide in and release 3 prongs that are holding the line onto the fuel rail. All 3 have to be released at the same time in order for the line to slip off the raised connection of the fuel rail.
yea, i have tried to use a screw driver to push them, but the manifold kind of gets in the way.
had visions of pulling out the sawzall and cutting the lines....
