Front turn signals wont work back does.
I just got this camaro and failed inspection because my front turn signals dont work at all. The light comes on as a marker at nigth but wont flash. It does flash with the car lock pad. the rear turn signals work fine. the hazards also work in the rear but not front.
is the turn signal a dual filament bulb or single? any ideas? i pulled the flasher and then all the signals stoped working. could it still be that? the light does come on with the headlamps. I have changed the bulb on one side and it did not fix the issue. let me knwo what you think. I cant drive the car till It passes. |
yes the front lights are dual element. i guess u need to track back looking for power start with the light bulb housing to find out which wire does and does not have power to it while the parking lights are on the the blinker for that side is blinking. u seem to have a wireing or ground issue.
I got it fixed.
I went and looked at the lights again when I took the bulb out of the drivers side the passengers side started working and has worked since. I messed around with the drivers side and never got it to work. the socket looked burnt so I got a new one and connected it up. still nothing. so I got creative. I ran a 16 gauge stranded wire from the rear drivers side turn signal to the front drivers side turn signal and wham its working. tucked the wires up and away. hid them and now you would never know I did it. thanks for the help all. glad to see I have a place to turn. |
