Front turn signal on 94 Z28
Ok so what's the best way to get to the front turn signal housing? I've got a new pair to install and it doesn't look obvious. Looks like I need to remove the slash guard and go from there. Any info/advice is appreciated.
is this it?https://camaroforums.com/forum/93-02...acement-72317/ can be found in the how to sticky at the top of the general section. here, lots of good info. https://camaroforums.com/forum/93-02...62/#post557634
No, not the switch the housing with the bulbs and lenses that's under the headlights. I'll look around a bit on the site.
yep you have to get at em from bottom. should be able to drop the back side of the bumper cover to get to em.
Thanks! Are there any special tricks to this? I attempted to change the turn signal bulb and that was ridiculous, I gave up and took it to the shop. But now that I'm changing both lenses I really need to do this myself.
have you downloaded the service manual? https://www.mediafire.com/?40mfgeoe4ctti click 1994 sec man. go to the electrical body and chassis section. should be directions on how to take them out.
