Front lower a arm removal?
I am having the hardest time getting the lower a arm out from my car to put my tubular ones in. I have the horizontal bolt out but the vertical one is giving me so much trouble. Ive tried propane torching it and hitting it with a sawzall but it wont budge. Its like the bolt is seized inside the sleeve. Anyone have tips to get it out? Ive already roasted the bushings with the torch so its coming out lol. I'm thinking I need an oxygen torch to get it out.
Welp I ended up using an angle grinder and partially cut the metal where it mounts to. so I just welded it up and called it a day. I am still not finished one side because my almost brand new KYB strut mount tore where the stud from the shock goes through and bolted to it. So now I have to replace that, and one of my moog ball joints didnt come with the metal plate to hold the boot to the joint. Oh well
They feel really nice on the road compared to my old worn out ones. And the springs are dark red lol but when I used the flash they look like that
Here's the spring manufacturers website if you wanna see the real color. VOGTLAND Sportfahrwerke & Gewindefahrwerke
