-   93-02 General (https://camaroforums.com/forum/93-02-general-41/)
-   -   Front engine oil leak (https://camaroforums.com/forum/93-02-general-41/front-engine-oil-leak-48262/)
Chinook311 Jan 26, 2010 07:56 PM
Hello. New member here. I have a 96 Z28 with 160,000 on the LT1. Lost the water pump and replaced it and the optispark. I thought I was careful but this was my first try at this. The engine got a little hot when the water pump failed but not totally overheated. When I start the car and run it for 5 to 10 minutes, oil starts leaking down from above the front seal. I am guessing either the opti drive or maybe the waterpump shaft. Anyone suggestions would be appreciated. Thanks, Chinook311
Camaro 69 Jan 26, 2010 09:29 PM
I have a feeling you may not have installed the water pump seal correctly. It shouldn't leak if done right, but it's a little tricky and the exact procedure seems to be a well kept secret.
Read this: https://camaroforums.com/forum/lt1-lt4-tech-9/installing-water-pump-drive-seal-43601/
z28pete Jan 26, 2010 09:34 PM
Could be either one, did you put new seals in after replacing the pump?
This is from http://www.malcams.com/legacy/misc/autorebuild.htm
WATER PUMP DRIVE SHAFT
Be sure to check the seal surface on the geared shaft that drives the water pump. If it’s grooved, it will leak and it will be your fault. New ones are available from GM (p/n 10219554) for around $40. That’s cheap insurance when you consider that the timing cover, chain and gears have to come off to replace it.
Chinook311 Jan 26, 2010 09:50 PM
Thanks for the ideas guys. Pretty sure I didnt pay enough attention on the water pump seal. I will update soon.
craby Jan 27, 2010 12:12 AM
these guys are probly right but just in case check the front of the intake manifold. the rvt seal there is prone to failure.
torque_is_good Jan 27, 2010 07:08 AM
you understand that the seals are not the little rubber o-rings?????????
I did not see in your post that you said you replaced the seals.
Chinook311 Jan 27, 2010 09:53 AM
I did not replace the water pump seal. Big mistake.
Chinook311 Jan 30, 2010 05:36 PM
Check this out..http://www.gmhightechperformance.com...ild/index.html
CamaroNut Feb 1, 2010 11:28 AM
Yea big mistake!
