finally on the road!!
Well, I finally got my 95 Z on the road yesterday. I went for an inspection sticker and it failed it due to a bad wheel bearing. They will fix that next weekend.
Overall, I spent the weeken on her. I fixed the dreaded wiper stuck problem. I had isolated it to a bad relay in the wiper motor electronic module but was not able to fix it reliably. I wish I could have found that relay, it seems like a part that will cost less than $10.00. Instead I had to purchase the complete assembly for $69.00. Anyways, it works well now.
I also replaced the front rotors and calipers, it stops much better now. Once thing I see is the ABS light coming on every now and then. It appears that the 17in wheels I have on the back are throwing the computer off since I have 16in on front. I will have to put everything to match, hopefully next weekend.
I also replaced a bad power steering pump. That was fun to remove and re-install but it is done and working very well.
I still need to replace the window motors but will do so some other day, hi hi.
As for the car, I had purchased it in March this year but had not driven it till this weekend. I am impressed as it is a 6 speed. I don't think I am going back to automatics any time soon. This thing is awesome.
Let's hope the fun lasts, it is for the most part stock so it should not give me much trouble.
Very nice car, it is my first Z28 on the road ( I have a 87 and a 89 being restored lol)
I can now see why so many people like this car.
thanks, I just wanted to share my "exitement!"
I will check codes as well.
WHen I worked for GM we would get people with ABS complaints just like you are describing and we found that if the tire size is too far different the computer in stock form gets confused about wheel slip and will flash the light. This can be programed out of the 96+ cars but I dont know about the 93-95 cars. This is why GM would tell you aftermarket rims could void all or part of your factory warranty. This problem is also more evident on the 4 channel system, the 3 channel system is not as complex and is not used in the traction control system. Most Z28s came with the 4 channel system even if they were TC delete.
Massey
Massey
