A few questions.
The "Low trac" keeps lighting up, Does anyone know how to fix it?.
I was thinking of going with some Lunati Camshafts, I was curious if anyone else had those? I figured i'd put it on my 02 Z28. And last, Does anyone know where I can get a white cauge for my Camaro? Preferably not $70 or higher which i've seen at most places. Thanks. |
RE: A few questions.
Anyone?.
There's a skinny pedal on the right, lighten up on it a little and that "Low Trac" light may just disappear...:D
As far as Lunati cams go, they're a reputable company, but picking out a camshaft shouldn't just be a spur of the moment decision or you're not going to get the results you want. Be sure to research exactly what you want to do and tailor your camshaft to that. |
Do you know what to do with the Low Trac light?.
To fix the 'Low Trac' light you're going to need to find out what's causing it to come on. For some reason the car thinks that one or more of the wheels is traveling faster than than the others. This could be because it really is (i.e. you're spinning the tires) or you could have a faulty wheel speed sensor. Is the 'Low Trac' light the only warning light on, or do you have an SES light on as well?
Yes, SES is on aswell. The Low Trac comes on from time to time.
Someone said it needs new 02 sensors??. |
Have the car scanned with an OBDII reader at autozone.. It's free and will tell you why your SES light is on ;)
I had it scanned there, Weird thing is they didn't get a reading. It didn't work for some reason..
Can anyone tell me where this front bumper came from?. http://camarographics.com/Sprewell.htm I am trying to make my Camaro look like that, and I wondere where the front bumper is from. |
Don't know where your bumper is from.
I can tell you for a fact that a faulty O2 sensor isn't going to make your Low Trac light come on. Your first step is to take the car somewhere to get the codes read, it may benefit you to take it to a dealership or another reputable shop that has more than the basic OBDII scanner so they can read the stored problem codes as well. |
It's not my bumper, I am wanting to buy one like that..I just don't know where to get it...
Anywhere beside AutoZone to do a reading?. |
