The famous question of all time. Check oil when its warm or cold
Old Oct 23, 2011 | 08:51 PM
bill2129's Avatar
Default The famous question of all time. Check oil when its warm or cold
On my 98 Z Iv'e always checked the oil after the car has been sitting overnight. So it all drains back to the pan right? Or do I check it after it has been sitting for 10mins or so? Because I keep adding oil every few weeks or so after checking it overnight. Now im thinking I might be over filling. I tried to look this up but some people say cold others say warm. So when Do I check the dip stick? How do I get the best dipstick reading?
Old Oct 23, 2011 | 10:33 PM
Does not make much difference, as long as it is between the low & high marks. A warm engine should be allowed to stand about 10 minutes to allow the oil to drain back, otherwise you will get a false low reading, and wind up overfilling. If the engine is cold, it should be checked before starting, otherwise you will have to wait a long time for the thick oil to drain back. As for expansion, 5 quarts of oil are not going to show an appreciable change in volume between hot and cold.
Old Oct 23, 2011 | 10:39 PM
iLL95's Avatar
I Like to Party
Super Member
Check it when it's been sitting and the engine cools;also allowing for the oil to drain back in the pan. Why do you add oil every few weeks? is the level going down?
Old Oct 23, 2011 | 11:24 PM
Failed Devices's Avatar
LS1's are sort of known for burning a bit of oil; unless you are adding something like a quart a week you should be fine if you burn a little
Old Oct 23, 2011 | 11:43 PM
bill2129's Avatar
Thanks. I add 1qt after 2400 miles or so. It used to take NONE... I change every 3k with Pennzoil Ultra or Mobil 1. Whichever i'm in the mood to buy lol
Old Oct 23, 2011 | 11:45 PM
bill2129's Avatar
Yes it gets close to the add line. More like every 2400miles I dump the whole qt in there. Then change it at 3k.. When I do a change I add 5qts and it reads full
Old Oct 23, 2011 | 11:58 PM
iLL95's Avatar
I Like to Party
Super Member
(Off topic) Nice maro btw. Like the color
Old Oct 24, 2011 | 02:38 AM
bill2129's Avatar
lol thank you. glad you like it (:
Old Oct 24, 2011 | 08:31 AM
torque_is_good's Avatar
hmm
on the LT1 I add 5 quarts and then an oil treatment which brings it to 5 1/2 quarts.
Don't the LS1's need 5 1/2 quarts?
Old Oct 24, 2011 | 10:39 AM
Overfilling is not a good idea. Too high a level in the crankcase will allow the crankshaft to hit the oil. This causes the oil to foam which makes the pump deliver an oil & air mix which causes oil starvation resulting in possible engine damage. The engine will eventually burn off the excess oil because the rings are not designed to control the amount of oil being slung into the cylinders and allow the oil into the combustion chamber. This can lead people to think the engine is burning oil, when in fact it is working fine.
