Exhaust?
Old 01-28-2008 | 05:12 PM
brooksr's Avatar
Default Exhaust?
I had a 94 Z28 with aftermarket exhaust and i wrecked and totaled it and now own a 98 Z28 and want to know if the exhaust off of my 94 will bolt up to my 98. i know they are the same block , but i didn't know what the underbody would intail. Please let me know if u really know. Thanks
Old 01-28-2008 | 05:16 PM
6v49der's Avatar
Default RE: Exhaust?
94 and 98 are entirely different dude, nothing will just "bolt up". Your 94 had an LT1 and the 98 is gonnna be an LS1.... two very different engines..
Old 01-28-2008 | 06:36 PM
brooksr's Avatar
well i know what motors i have and i just wanted to know if they would have the same exhaust manifolds? but thanks for the advice.
Old 01-29-2008 | 12:18 AM
95slvrZ28's Avatar
Just because they have 2 different motors doesn't mean that the exhaust is going to be completely different...You would be able to salvage your cat-back and that's about it, the Y-pipe and manifolds are different between the two engines.
Old 01-31-2008 | 08:18 PM
Saint_Ali's Avatar
correct, all he would have to do is cut and do some welding or get and exhaust clamp to hold it together, i would recomend welding it as there would be no exhaust leaks
Old 02-01-2008 | 05:51 PM
baseballer91's Avatar
didnt the 94 still have a single cat and the 98 have dual?
Old 02-01-2008 | 06:18 PM
The Banks's Avatar
LS1 Camaros had a single cat with a Y-pipe
Old 02-01-2008 | 06:34 PM
qmracer's Avatar
You mean LT1 right? My car has dual cats.
Old 02-01-2008 | 10:32 PM
sl1foru's Avatar
he should be able to use the aftermarket exhaust as far the muffler and the tips. i used a hooker aero chamber muffler exhaust off a 2001 z28 camaro and but it on my 1993 z28 camaro. so that should work.
Old 02-01-2008 | 11:11 PM
JHL88's Avatar
ORIGINAL: qmracer
+1
the left cat is tucked up and hard to see just by looking at it, the right is about 8 inches to where the y pipe merges
