Everythings dead!
Old 03-05-2012, 12:22 PM
Chris Wood's Avatar
Default Everythings dead!
All my electronics are dead! just happened and im stumped. everything was working fine and then i stopped at walmart for an hour came back out and nothing works. starts and runs fine but the rach, speedo, radio, fuel guage, dash lights everything is dead.. checked all the fuses and there fine. havent pulled the bcm yet but i dont think thats it. any ideas ?!!? im lost
Old 03-05-2012, 01:35 PM
Chris Wood's Avatar
Not the BCM either, just pulled it and checked my reflows from earlier this week.... im lost :9
Old 03-05-2012, 01:56 PM
need to track where the power or ground stops. check for power at your fuses. if power is there check grounds. not sure on the newer style but on the lt the ground for that stuff is on the door jam area under the kick pad on the driver side.
Old 03-07-2012, 05:17 AM
Chris Wood's Avatar
Checked the grounds.. still nothing. Checks all the fuses still nothing.
Old 03-07-2012, 10:05 AM
May have blown a fusible link.
Old 03-07-2012, 11:38 AM
DashingDaryl's Avatar
Did you say you just reflowed your BCM earlier this week? That seems very coincidental.
Do you know anyone else with a similar Camaro?
Old 03-07-2012, 03:35 PM
Chris Wood's Avatar
yes i reflowed but we checked the bcm, friend has same model year type of camaro and we put his bcm in ( he only has 54k miles) and nothing changed. so ive ruled that out.
i did just notice the TAIL LPS and guage fuse was blown. so i changed the gauge but the TAIL LPS blows as soon as it touches the fuse box.
Old 03-07-2012, 04:54 PM
sounds like its shorted to ground, follow the wire harness in the hatch area to see if you can find anything
Old 03-07-2012, 05:48 PM
Chris Wood's Avatar
It seems to have fixed itself.. i checked the wires and found nothing wrong. And somehow its working again. Im still confused but ty for the help everyone
Old 03-07-2012, 05:59 PM
oldman9's Avatar
Its good that its working now, but you should still look for where it shorted. Just a bump in the road or shutting the trunk a little to hard might jar it back into place and you blow your fuse once more....
Quick Reply: Everythings dead!
