engine stalls sometimes
Old Jan 9, 2010 | 03:31 PM
capteasy300's Avatar
Default engine stalls sometimes
98 v6 5 speed 3800l camaro. Runs great except when I slow down for a stop sign or red light, the engine stalls sometimes. I cleaned the throttle body and WD40 all the springs and linkages to the throttle body. New fuel filter, and fuel pump works o.k. Any suggestions?
Old Jan 9, 2010 | 04:44 PM
IAC valave comes to mind, and possibly the TPS sensor.
Old Jan 9, 2010 | 07:42 PM
imalixZ28's Avatar
i dont know anything about manuals but could it be intake manifold? once the car stops at a light if its malfunctioning , no air flow = dead engine?
Old Jan 9, 2010 | 08:46 PM
There are no moving parts in the intake manifold to malfunction. But, make sure to release the clutch when coming to a stop.
Old Jan 9, 2010 | 08:49 PM
clean the iac (idle air control) motor also called a valve. when was the last time uve had new plugs?
Old Jan 19, 2010 | 09:35 PM
miguelad17's Avatar
Hi friend,
I own a '93 Camaro V6. I have the same problem that you, and reviewing the manual, I was checking all the electrical connections of the engine.
I did note, that the knock sensor connector cable is in really bad shape and I think that here is the problem.
Best Regards!
Old Jan 27, 2010 | 03:37 PM
It was the IAC module. The IAC module sensor had a black residue on it. I cleaned it off and it helped but eventually I replaced the IAC module and it's fixed. Is this common for a 12y old car with 110,000 miles?
Old Jan 27, 2010 | 04:23 PM
sure seems to be a rash of em going out here lately. great to hear u found the problem.
Old Jan 27, 2010 | 05:12 PM
imalixZ28's Avatar
Probably all junked up with carbon like mine was. I cleaned mine and it works great but sometimes depending on how much junk is on there you can fry it and it wont respond at all. My sensor was good but the actual IAC motor was gunked up.
I'd say it's pretty common, my 94's got 63k miles and it was gunked up enough to mess with my idle by 500rpms.
Old Jan 27, 2010 | 05:48 PM
If thats the case, could the engine have carbon build up too? What kind of cleaner can I use to get rid of the carbon build up inside the engine?
