Engine Restore Lubricant work?
hey guys im just wondering if that engine restore lubricant crap actually works cuz i was thinking about buying some since my z28 is getting around 100,000 miles on it and i want to get my horsepower back. anyways have anyone of you guys used this stuff and has it worked? or just screwed up your motor? i want to put it in a 1995 LT1 btw
ORIGINAL: Z28 Kid
no it doesnt. if your motor is that beat up then you need more then a $5 can of crap... by the way, mobil 1 does wonders...
yes it works great on worn engines. it won't repair a broken piston ring though.
check out these links
Im pretty sure that 6th link proves this product DOESNT work. Who is this guy a Engine Restore salesman who works on commision? DONT PUT THIS GARBAGE IN YOUR CAR. IT IS SNAKE OIL.....
All it is is a very heavy lubricant. Works initially but breaks down quickly, and then you are back with a smoker. Don't believe that crap about the lubricant penetreting into the metal either.
ORIGINAL: z28pete
READ:
Snake Oil!:Is That Additive Really A Negative?
Article and Photos by Fred Rau
ROAD RIDER/August 1992/Pg 15
Information for this article was compiled from reports and studies by the University of Nevada Desert Research Center, DuPont Chemical Company, Avco Lycoming (aircraft engine manufacturers), North Dakota State University, Briggs and Stratton (engine manufacturers), the University of Utah Engineering Experiment Station, California State Polytechnic College and the National Aeronautics and Space Administration's Lewis Research Center.
Road Rider does not claim to have all the answers. Nor do we care to presume to tell you what to do. We have simply tried to provide you with all the information we were able to dredge up on this subject, in hopes it will help you in making your own, informed decision.
You Can't Tell The Players Without A Program
On starting this project, we set out to find as many different oil additives as we could buy. That turned out to be a mistake. There were simply too many avail able! At the very first auto parts store we visited, there were over two dozen different brand names available. By the end of the day, we had identified over 40 different oil additives for sale and realized we needed to rethink our strategy.
First of all, we found that if we checked the fine print on the packages, quite a number of the additives came from the same manufacturer. Also, we began to notice that the additives could be separated into basic "groups" that seemed to carry approximately the same ingredients and the same promises.
In the end, we divided our additives into four basic groups and purchased at least three brands from three different manufacturers for each group. We defined our four groups this way:
1.) Products that seemed to be nothing more than regular 50-rated engine oil (including standard additives) with PTFE (Teflon TM) added.
2.) Products that seemed to be nothing more than regular 50-rated engine oil (including standard additives) with zinc dialkyldithiophosphate added.
3.) Products containing (as near as we could determine) much the same additives as are already found in most major brands of engine oil, though in different quantities and combinations.
4.) Products made up primarily of solvents and/or detergents.
There may be some differences in chemical makeup within groups, but that is impossible to tell since the additive manufacturers refuse to list the specific ingredients of their products. We will discuss each group individually.
The PTFE Mystery
Currently, the most common and popular oil additives on the market are those that contain PTFE powders suspended in a regular, over-the-counter type, 50-rated petroleum or synthetic engine oil. PTFE is the common abbreviation used for Polytetrafloeraethylene, more commonly known by the trade name "Teflon," which is a registered trademark of the DuPont Chemical Co
who the hells gonna read that whole thing... [sm=boosign.gif] what a waste of time
Then don't read it but appreciate the great info he's giving you.
ORIGINAL: yourGrandma
oh - and I guess you have to have some basic reading skills.
dude... long story short... i used it and my engine ran like crap... it was bogged.. i spend 5 bucks to "restore" my engine only to pay 20 bucks for oil and filter and change my oil... with in a week... Had i let it go longer i probably wouldnt have a running car right now.. that vendor up there is just trying to get you to buy his product.. its worthless... just change your oil regularly with good synthetic (i use mobil clean7500 and it has been good to me thus far)
