Engine locked up???
If the motor will not turn over with a 30" breaker bar with one hand its done. This is why the mechainc did not offer to check out the motor any further it is a waste of time and effort.
Ya cannot trust lube monkeys as far as you can throw them -- one couldn't even locate the PCV on my RS, much less tighten the air valve caps! ![Icon Rant](https://camaroforums.com/forum/images/smilies/icon_rant.gif)
It is so easy to test for I cannot remember anyone misdiagnosing a locked up motor. Heck if the oil change guy told me a motor was locked up I would assume he was correct. If your mechanic told you a motor was locked up and it is not then he should be in the running for the dumbest mistake ever.
I know mechanic have a bad rep but to tell someon there motor is lock and it was not would just be plain stupid. (Almost as dumb as telling someone you did a rebuild when you didn't.) It is real easy to check, Heck a guy with strong hands can turn the motor over with is hands. All you needs is for your customer to have one person in his family that knows basic mechainc and you lost a customer for life. This type of thieft by deception would be a felony and very easy to prove. If your going to get ripped off mechanics are looking for Gray areas and a bunch of little things or something few people understand like computers or automicat trans.
It also doesn't make sense that the engine was running, was shut off, and now it's seized?
Not if the starter is jammed, I've had it happen before. Could be the mechanic is just assuming the engine is locked up because he can't turn it over by hand, just like what you're saying here.
It just seems weird too, that the engine was running, was shut off, and now it's seized?
So the theory is while the car was idling the over running clutch jumped out and jammed up so bad in the flywheel it stopped the motor and now its locked up? I have seen starters blown a part that did not see near that kind of stress but I guess thats possible. Heck I am just going by the few dozen locked up engines I have fixed.
Quote from the first post: "She was at gas station and it made a weird sound (she cannot define weird) and she shut it off. Now it won't start". She shut the engine off, it didn't kill itself.
That's how it happened to me once. All was fine, until the next restart, then the bendix gear jammed into the flywheel. The engine wouldn't turn over, not even while dragging it behind another car (it had a manual trans). Yep, my engine was "seized" too, that is, until the starter was removed.
Now mind you, I'm not saying it's definitely the starter, only that I would check that first before assuming the engine is toast.
if the starter ingaged while it was running that would explain the noise and if she shut it off then the starter by then may have been fried and stayed ingaged. lol. all speculation and makes a good story. but yah take the starter out and see what happens. wont cost anything and just might be the problem. wow the op has been a member a long time.
