Electrical problem
I have a '95 V6. I've been having a problem with the battery draining and have been unable to track the problem down. I just installed a new head unit, subwoofer w/amp and ran new speaker wires and a new very strange problem has come up and I think it may be related to the RAP module. After I turn off the ignition and open the door, the radio turns off and the windows stop working (as it should be). A few minutes later, the radio turns itself back on and the windows start working without the key in the ignition. It originally had the Bose system in it and I'm thinking that the RAP has been turning on the amps on the speakers and causing the battery drain all along. The original head unit didn't turn back on, but it was almost totally dead so it may not have been working right anyway. Is this the RAP module causing this? I didn't see anything in the existing threads that was similar. Is anyone else having a similar problem? Any advice would be much appreciated.
could be the bcm is acting up. look here and see if it helps. https://camaroforums.com/forum/93-02...-repair-52062/
OK. Pulled the RAP module and resoldered all the joints and cleaned the connector pins. The problem persists. I think that the one and only IC on the circuit board is bad, but it's a surface mount chip and I don't have the equipment to replace it even if I can find a new chip. Is there a way to bypass the RAP module all together? I'd rather not spend the money for a new module since I really don't have any use for the feature. I really don't mind if the radio shuts off when I turn the ignition off (that's what ACCY is for).
I will double check it, but the stereo works right otherwise. I did have the battery drain problem before the stereo, but while I was looking for the RAP module, I found an aftermarket alarm and I yanked that out. Really good alarm that you can just unplug it and disable it, huh? LOL I think the alarm was the problem, since the power drain seems to have stopped. Now I just have to figure out why the radio and windows activate after the ignition is off. Is there no way to bypass the RAP to test my theory about it causing the problem?
