EGR Disconected
The tube leading from the EGR valve to the exhuast manifold was cracked and leaking. so when i was one the gas i could here it flowing out pretty good. i tried a bunch of times to fix the hole with "The Right Stuff instant gasket" but that didnt work so i decided to just plug it i cut a 2in piece of steel drilled a hole through for the bolt and gooped it up with a bunch of Hightemp rtv(the stuff you use when you redo a intake gasket) and i pluged the hose going to the valve with the right stuff. this is ok to do correct its not gonna throw a code? i know i should have asked before i did it last night but i was on a roll after fixing the antifreeze leak on the hoses that go to the heater core
Might be a match for my vacuum elbow that has one end held together with a piece is sheet metal wrapped around it, RTV, and two small hose clamps! Not much to look at, but works, and done with the parts that were available at midnight!
![Icon Wink](https://camaroforums.com/forum/images/smilies/icon_wink.gif)
Well you could take it to a shop that does it, or you could do it yourself. I bought tunercat and deleted mine with that program. Or just find someone around you that has a program that can delete codes.
it will through a code for "egr low flow-check pintle valve, connector...." my blazer's was clogged with carbon. i fixed it and decided that having it functioning really hurt the part throttle response and power, and hurt fuel economy, and just unplugged it
