Egr
Diaphragm type vacuum operated EGR valves are ancient history. The exhaust gas flow can't be controlled precisely enough. A lot of really modern cars don't even *have* EGR valves -- exhasut gases are recirculated using their variable valve (intake/exhaust) control systems.
The 3800 EGR valve (and even the 3400 before that) is an electric-only digital valve. The 3400 used 3 on/off style solenoid-operated valves. The PCM can operate #1 or #2 or #3 individually or #1&2 or #1&3 or #2&3, even #1, 2&3, to get the desired exhaust gas flow.
One of the solenoids can stick or fail electrically. An orifice can be plugged by debris (carbon). The tube between the exhaust manifold and the valve can carbon up as well.
On the 3800 the EGR valve has one large winding that is divided into several sections which can be energized separately. That allows the single valve pintle to be opened various amounts but in steps for precise control.
My point is that an EGR code is not necessarily a death sentence for the EGR valve (but this is a common service station reaction). Then, when the new valve doesn't solve the problem they can shrug and tell you that electrical parts are not returnable and you probably needed the valve anyway becasue your car is old and has XXXXX miles on it.
If you can, find someone with the GM Service Manual for your exact car and look up the trouble tree diagnosis steps for the code you see.
