Drivers side window
rolled them down during the day in my red 99 3.8l,last night went to roll them up ,drivers side one wich was replaced an worked great just stopped working I hear some noice from streeing area when I hit the button is there a relay I don't have a manual with mine the passngers is the slow one so I was surpized, if I can get it up I would just leave it up until can fix it ,any help will be great thanks
Moved to the fourth-gen forum for you. ;)
ok thank you ,now I got 2 threads hear an still got a window stuck down ,a yeak comeing from vent ,is there a relay any fuses under hood connected to windows ??? there blue grey an brown ground wire at the switch ,an the passengers window works is the slow one or was until that one stopped .the motor is only about one .year old,is there a schematic hear anywhere that's clear to see how the windows work wireing Di.agram,is there a way to get it up I would think if. one takes the panal off mabey jump is to go up ,an keep it up until can figure out the issue.oh an there is power there ,th.at yeak .noise has got me, is there something under the dash. like. a relay ,thought. is bad switch or power at the motor ,if there are no other relays fuse was first thing .checked an works
ok I guess everyones working ,like said pass side works 99 Camaro 12 volts both sides drops.to zero ,? could passengers side work a not drivers side ,an this module I can hear it yeaking louder .with the center concole off ,but it seems its either under the car or.further in , has to be those 2 ,now I have though about buying a switch ,but module cant find it an don't get anything when I google it ,checked all relays that I know of ,module or switch ,when I can find module ,I should have given .enough info .its waiting now on a response as I have done all I can for now,i don't like the word hate but I hate power windows ,time for a ride in purple car
