driver side shock to rearend nut spinning
I won't get into nut splitters. Being married as long as I have I've had my nuts split.........ahh, never mind.
anyway, put a open end wrench on the top of the shock stem which you reach from the inside of the vehicle and away you go.
"pay closer attention to topic heading"
Set of torchs works wonders. I have gotten shocks off faster than it took the customer to tell me about all the things he tried that did not work. With a little practice you can be a like a surgeon with a torch
But good luck torching off the lower nut without giving the axle shock stud a melt down. That's where the issue is (according to the guys description).
