Doors
Old Jul 22, 2011 | 11:20 PM
jrgearhead's Avatar
Default Doors
So like a dumbass i was going in reverse messing with a friend walking behind me and my passenger didnt close my door and it cought a mailbox and bent it to where it wouldn't close and i think the hinges are bent. Just wondering if anyone has messed with this stuff before?
Old Jul 23, 2011 | 06:48 PM
i would think it would tweek the door before the hinge. you may end up having to get a new/different door. they are mostly fiberglass.
Old Jul 23, 2011 | 09:11 PM
The door is a metal frame, with a plastic skin. Same goes for the hinge pillar. So yeah, you could have bent either one, or both. Detailed pictures may help for us to see what got tweaked.
Old Jul 24, 2011 | 11:37 PM
jrgearhead's Avatar
okay ill get some pictures up its all apart right now so tomorrow im going to bolt it all back up real tight and hope for the best
Old Jul 25, 2011 | 08:38 AM
Grandpaswagon's Avatar
The bad thing about bending the front of the door frame, where the hinges mount up, is that it really takes a good body shop to fix it right.
I have seen several cars that once that front hinge frame gets bent, the door never seems quite right again.
If you lucked out and only mangled the door, then that is pretty easy to replace with one from a scrap yard.
Old Jul 25, 2011 | 07:02 PM
jallen100's Avatar
Unless there is some major structural damage then a body shop is just going to yank and pull on that door until it straightens up. I'm not a body man , but I worked for a very large body shop for a couple of years and watched this being done over and over again.
Old Jul 25, 2011 | 08:19 PM
Massey's Avatar
Yank and pull? Yes we can tell you are not a body man. THese doors are made out of something calle SMC which is like fiberglass only 10x stronger. The door has and internal metal frame at each end with a HSS steel bar connecting both sides for strength and collision protection. This frame is not repairable nor is the inner SMC structure of the door. Replace the door and if any damage happened to the cowl of the car then have a body shop take a look at it for proper repair. Get some new hinges with the new door as well. Hinges can be bent but look normal and will give you all sorts of grief when trying to get everything to line up.
And if you are wondering about my qualifications on this advise, I used to be a body man and painter. Check out my build log on Sarah and you can see what kind of work I can do. Oh and the door on Sarah while minor damage on the outside the entire door needed to be replaced because of damage to the inner structure.
Massey
Old Jul 25, 2011 | 11:44 PM
jrgearhead's Avatar
I dont think the door is really bent at all its ether the hinges or the frame is bent a lil its just a hair to far forward when i try and close it. Got the bottom hinge to bolt up but couldn't quite get the top one to line up
Old Jul 27, 2011 | 12:17 AM
jrgearhead's Avatar
Okay so got it bolted up really good and used a impact socket wedged between one side of the hinge to the other closeing the door to bend the hinge back flesh with the wall of the car which is what was actually tweaked and then i had to just lift up on the door real hard a few times and she slid right back into place
Old Jul 27, 2011 | 06:54 PM
jallen100's Avatar
Just like I said
